Rhino 8 as far as latest release. @chriswmackey can confirm this.
Fairyfly works in both Rhino 7 and Rhino 8. It probably also works without issues in Rhino 6, though I have not tested this.
See above, @ojhamadhavi96 that you probably have to run the LB Versioner a couple more times. Or you can use the more reliable way to get the components right now - download and run the latest Pollination Grasshopper (or Rhino) installer. This installer now has all of the Fairyfly components and core libraries with it.
Hello, I tried to use this file and I got this error : "1. Solution exception:âModelâ object has no attribute âclassified_envelope_edgesâ
What should I do to fix it?
Thank you
Hello everyone!
This was a great discussion. And even though it was not related to Pollination I let it go on until we officially release Fairyfly. Now that the release has happened, Iâm separating it into a separate topic so I can close it.
Please use the Fairlyfly category in Ladybug Tools Discourse for all the follow up discussions on the topic.
Thank you again for all the great helpful feedback. We appreciate it!
