Loading Pollination.GH.gha issue
I’m not sure if this is a Pollination or Rhino issue, but it started today.
When i run Rhino+GH during the load process I get the following conflicts. They appear 3 times during the load:
Not sure if this started after I updated to latest Rhino [8.14.24325.13001, 2024-11-20] or updating Pollination. In any case, decided to report here just in case.
-A.
Hi @ayezioro,
Thank you for sharing this. If you check the paths in the error warning you see that it is asking you if it should load the gha files from the Rhino 7 folder or the Rhino 8 folder. This happens when you have the plugins installed for both Rhino 7 and Rhino 8. The solution is to install the plugin for Rhino 8 only once so Rhino 8 set the loading path to the Rhino 8 folder, and then you should be fine to install it for both versions. See this post for more information:
Thanks @mostapha ,
Missed this one. Now it works fine.
Best,
-A.
