Project Info - Not able to use local EPW
Rhino 8.12 running under .Net Core
Using version 1.52.20. This still doesn’t work for me.
I have installed this version by following these steps.
I have downloaded an EPW folder locally
I have referenced the folder like so
Location is correctly obtained
Sunpath command still doesn’t find the EPW file.
Another issue
One has to manually remove the quotation marks from the path. With it, obtaining location does not work.
