I wonder if the Revit plugin will be able to export data if Revit is run in viewer mode, with or without changes to the Revit model? The reason I ask is that I do not want to buy a Revit license only for exporting data.
This has been tested by @maxt and we know that the Revit plugin works with the Revit in viewer mode.
A post was split to a new topic: What are the limit offset and base offset referred to in the setting?
