Setting up the right room height?
Hi @davi,
You should always use the extruded mode. Even for the rooms with inclined roofs. The roofs are automatically resolved by the Revit plugin. We’re removing the Full Volume option from v3.
Because almost always the values are left to the default value and not set correctly.
I’m not sure what is going on with your model. If you can share the model with me, I will have a closer look. I can’t replicate the issue on my end.
That said, and to answer your second question, the better place to set the room height is the Model Editor. See the discussion here:
Let me know if you have any questions.
