Setting Wall Boundary Condition
Hi @mostapha,
What would be the best way to set the following wall as exterior:
I have the top exposed set to true on the adjacent space but the walls are slightly different heights. I solved the ceiling adjacencies as well. Seems like the wall is not being split to account for the exterior portion.
I messaged you the pomf file for reference.
Hi @marentette1, good question. I was also confused about this behavior not long time ago. See @chriswmackey’s answer here for a similar case.
You need to set the rooms next to this room on the ground floor to be top exposed.
And that will change the boundary condition from adiabatic to outdoors. There are two other rooms that need a similar approach. But as you can see the one that you showed in your screenshot is fixed after I made the change.
@mostapha
Yes, that sets those small strips to the correct boundary condition. But when I import into eQuest, it doesn’t update those top surfaces to interior:
Hmm. Let me check. Just to make sure, are you selecting the solve ceiling adjacency option when exporting the model?
@mostapha, yea that fixed it. Thanks!
