Setting Wall Boundary Condition
Hi @marentette1, good question. I was also confused about this behavior not long time ago. See @chriswmackey’s answer here for a similar case.
You need to set the rooms next to this room on the ground floor to be top exposed.
And that will change the boundary condition from adiabatic to outdoors. There are two other rooms that need a similar approach. But as you can see the one that you showed in your screenshot is fixed after I made the change.
