Shades Importing as IESVE Adjacent Building
Hi @crduggin,
The option was always there but in the classic version we used to set the detached value to true only for plants, and it was set to false for the rest of the shades by default. I will document this for @ksobon so we will get it fixed.
I noticed this during the SimBuild workshops and fixed them manually in the table. You caught it before we get a chance to fix it. :sweat_smile:
Yes. That should be possible. That’s a bug! For now, try using the Pollination Classic for exporting them. Select the linked model in the dropdown, and then use the Add Shades from link to add them. We will fix this for you!
Two bug reports in a single post! Ha. Well done! :slight_smile: :raising_hands:
P.S. Am I right that you are not facing any of the issues that @mdouglass is facing here? Aren’t you using machines with the same set up?
P.P.S. Let me know if you have any other feedback about the new UI/workflow. I was hoping to catch up at SimBuild but unfortunately that didn’t happen. Hope you are feeling better, already!
