Hi there, I’m getting a consistent error where my UTCI study keeps failing… Seems like the pollination component is not uploading my csv file?
Hi @jakechevriersg, What do you see when you click on the air-speed-matrices
folder?
Do they follow the requirements explained in the input?
cc: @chriswmackey
this is what is in the air speeds-matrices folder… i don’t see a csv file, and yes i believe i have it correct, I have a csv file with 538 rows (# of grid positions) with 2160 columns (hours of analysis period)
this is my csv file which matches the grid name in my gh script…
Hi @jakechevriersg,
I checked, and I can confirm that it uploading the wrong files. Do you have any idea where those 3 files are located? For some reason, the input picks up a different folder with those 3 files instead of picking the correct folder.
I have two guesses about why this might be happening:
Can you remove the
from the end of the folder path?
If that doesn’t work, can you put the path in " " or use a different path without a white space?
2 posts were split to a new topic: Integrating CFD results into UTCI calculation
