PO Dump GEM (Error code: 54-Invalid license key)
I am fairly new to pollination, I wanted to use the Grasshopper Plugin to bring a model geometry to IESVE. I have an account and logged in, but I still get this error in grasshopper, and I am not sure what to do here. I thought the grasshopper plug-in was Free. See image below.
Hi @franciscocontreras, and welcome to the community!
I can see how it can be confusing, and I suspect this is related to the issue that was reported here:
Did you install the Pollination Grasshopper plugin or the Pollination Rhino plugin? The Grasshopper plugin should only include tabs 2:Pollination and 3:Parametric. And work without using a license.
Tabs 1:Primitives and 4:Serialization are part of the Rhino plugin and need a valid license. They should not be installed as part of the Grasshopper-only installer.
Sorry about the confusion.
You are right the Rhino Plugin was installed instead. But it seems the issue is with the installer currently on the website. As you can see below the installers is the GH, but when it opens it does say Rhino.
Hi Mostapha, any chance you can share an older version of the GH installer?
I can share an older version of the installer or a newer version with the fix for not installing the Rhino plugin with you but it won’t make a difference in what you are trying to achieve here. You will need a valid Rhino license to be able to use the under the 4:Serialization section.
I see, thank you for answering. Initially thought all the GH plug-in features were free. But I guess that Serialization would not install with the GH plug-in in this case. I got confused when I got those options thinking I was getting the GH plug-in when I got the Rhino one instead.
